giovanni0502
- PA
Hello all, I am an electrical inspector who worked as an electrician for 14 years before getting into code enforcement. I ran across a situation with a home having a 100a overhead service:
The homeowner had his roof redone and a soffit added. It was brought to my attention via a photo from a fellow code enforcement officer that the triplex now runs into the soffit and splices on to the SE cable above the soffit with no access from the attic and the SE cable then comes down out of the soffit to the meter. When I looked into code sections to cite the homeowner with, I couldn’t find much. I see SE cable has to be spliced in a box per 2008 NEC 230.46. I know that open air splices are allowed at the service point but don’t see where, nor do I see where this splice has to be exposed (unless the “utility rule” cones into play but customers own the service drop so I doubt it). Now I have a leg to stand on due to the fact that the SE cable is subject to physical damage from the soffit but I would like the forum’s input on a more solid argument.
