I have a 150amp outdoor non fused disconnect on the outdoor service pole feeding an indoor 150amp main breaker panel box.  The indoor panel needs to be replaced.  Residential.  The indoor main breaker melted.  There appears to be no other cause for the melted main breaker except for the dead lizard I found behind it.  Can I replace the 150amp panel box with a 200 amp panel since the outdoor disconnect would trip at 150amps?  Assuming the wire is sized for 150amps.
