badgerfan08
I have a question regarding a situation I personally have not yet encountered but want to figure out. The situation is you have a large garage and a home separate from each other. They are maybe 500' apart. The garage was built before the home but power was run on to the property for construction purposes before either were constructed, so there is a free standing meter pedestal. How would you run you feed to the house and to the garage and keep just the one meter in the same location. Do you just need a disconnect on the outside of the house and garage? What type of wire would be needed for this? It would have to be rated for direct burial,etc. Is that ok to do, feed two buildings from one meter, two lines on each lug of the load side of the meter socket? Just looking for some clarity. Thanks.
