service rated single pole switch
I'm being asked to to install a service rated switch on the outside of a building for a light fixture fed from another building. Is there a service rated single pole switch?
If it is a non-dwelling unit isn't the inspector correct? 225.36
Yes, I was assuming residential with just a light but I may have assumed to much. Personally I think that is a bad rule and I believe Chris wrote a proposal to take out the exception for residential. Hope it passes.
