Cow
- Eastern Oregon
- Electrician
Customer lost a leg to the panel. Stabbed my probes into the overhead connections and had good voltage. It must be behind the meter?
It was a MIRACLE the wire didn't fault to the meterbase hub. It was right up against it and most of the insulation was gone as you can see in the pics.
Also one of the tallest masts I've ever installed. I wasn't entirely sure if it was required or not, but all my measurements said I had too many feet of aerial cable over this 3/12 pitch roof to get away with a shorter one.
