I am working on a storage mini-warehouse building. It is 11,200 sq/ft. 58 individual storrage units. General wants 1 keyless fixture in each unit with a 100 watt bulb. Each unit will also have one receptical. Would I use table 220.3(A) to figure the lighting load? Would this be considered a warehouse? What load should be figured for the recepticles? There are also 8 outside fixtures that will pull 4 amps each. This will be a single phase service. Thanks in advance for any help. Using the table mentioned above and appendex D it doesn't seem to call for a very large service. Tim
