Service switch grounding sketch
cppoly
New York
Looking at the attached sketch, can someone let me know what the purpose is of the green conductor (that I pointed to) for the fire alarm service switch??
Looks redundant and not required.
  • Service Switch Grounding Sketch.pdf
This is NYC F/A so good luck getting an answer as to what is actually required. They are so far behind the times that if you look closely at the drawing you'll see they still are using fuse panels for the branch circuits. :rolleyes:
