A friend of mine bought an old home that has a service with fuses instead of breakers. At the top the feeders (they look like at least a #2) come in from the meter socket and land on a set of lugs which are the line side of the main fuse (60 amp fuse). Is it permissable to tap off of these lugs with #6 THHN to feed a sub panel (right next to it) via a back fed 40 amp breaker using a hold down kit? It seems to me like a violation unless the tap was on the load side of the main fuse. But the circuit using the tap conductors are protected by a 40 amp breaker. BTW he want to use this sub panel solely for a 3-ton A/C unit. Also, if cost permits, he is considering changing out the fuse box to a breaker box (the meter socket is a separate box above the fuse box connected with a 6-8 inch nipple). Can this be done without disturbing the meter socket and mast assembly? Thanks.
