This is my first post, so if I have posted this in the wrong area... yada, yada. I apologize. That being said, I am having some difficulty deciding which direction to go. Heres the run down. I have a commercial building that I need 480v 3ph power to operate a lathe, a milling machine, and a boring mill . I also need 120v for my lighting.. No big deal right? Well, I also need 220v single phase to run 2 of my Lincoln Welders and maybe my plasma cutter. What would be the easiest way to reach all of these goals with the least expense or least headache (time is also money). Everyone I talk to has an opinion which conflicts the last. I can't get a straight answer from anyone. I have an electrican, but I want to know that what he says is correct. I know this is a tall order, but any help would be greatly appreciated. I feel that with the cost of labor and the quality we as consumers receive in the end, you really need to have some good knowledge of what you are doing/having done to reach a favorable outcome. I have knowledge of three phase power, as I deal with inverter motors and VFDs daily as a distributor. The transformation and available options have me kinda stumped.
The load list is as follows. These are not breaker sizes, just load ratings for equipment or a given area.
Office Area................ - N/A 120V 1ph 60hz 20A
Shop lights/recpticles.. - N/A 120V 1ph 60hz 40A
Lathe....................... - 10hp 460V 3ph 60hz 13A
Bridgeport Mill............ - 2hp 460V 3ph 60hz 1A
Boring Mill................. - 10hp 460V 3ph 60hz 15A
#1 Lincoln MIG 255C... - N/A 220V 1ph 60hz 55A
#2 Lincoln MIG 255C... - N/A 220V 1ph 60hz 55A
ESAB 1250 Plasmarc... - N/A 230V/1/3 or 460/3 66A/29A/20A
Dake ColdSaw........... - 3hp 220V 1ph 60hz 15A
The power I am expecting to have run to the building is 480/277. I was going to run a straight 480v, but the addition on the 277 (neutral) will give me more options.. Right? The only transformers I see are 480V-Delta to 208Y/120. How do I get 220V single phase? Each leg of the "Y" represents a 120V/1ph leg for three total. Maybe the answer to the 220v/1ph is ridiculously simple and I just don't realize it.
Thanks!
Thanks!
