Im upgrading a service on a house currently the house has three 60 amp meter pans and 60 amp federal pacific panels. The meters are located inside the house along with the panels. The panels feed the apartments in the house. I'm going to move the meters to the outside. I was going to run 200 amp seu down to a trough then run 100 amp wiring to each meter pan. I was going to use offset nipples to each meter pan. Is this ok to do or does anyone have any other ideas
Thanks in advance
Thanks in advance
