ceb58
- Raeford, NC
I have the answer from the head inspector but would like to see what your call is. This is a job I am looking at to bid.
Home has 200amp service (back to back) They are doing another addition which will throw the calculation over 200. Here is the plan. 200 meter base is between the garage door and a window in garage. I plan on installing a 400 meter base on an adjacent wall that comes out at 90 deg. From the new base I will pipe over and 90 back toward the old base. Remove the old base and install a J box and splice onto the existing 4/0 alu. seu. On the other side of the 400amp I will install a 125amp disco run down and into basement with ser for a new sub panel. My question to the inspector was would he allow the existing 4/0 seu to stay keeping the 200amp rating or would I have to tear it out to the panel and replace with large seu. How would you call it?
