Alphabet
- Jefferson City, MO, USA
Here is the situation: 208Y120 3 Phase service, multi-tenant space. 800A Main disconnect to meter bank of 6 meters with 5-200A disconnects and 1-100A disconnect. Sleeves through outside wall to pull box on interior in ceiling space. Conduits branch from pull box to tenant spaces to panels. Conduits run through fire walls to other spaces and are sealed at walls. Only two tenants-one taking 3 units, and the other taking 2 units. Green tags for up to rough, cover in 3 unit space, no build out in 2 unit space (open). Service inspected to 800A disconnect and released to Utility for transformer install. Situation brought up by arch. doing build out for 3 unit tenant and then expanded by GC. No input from inspector. (More concerned about multiple to one metering for the tenants.) Just looking for answers and suggestions. Considered service or feeders based on main disconnect being at meter location? If needed, would 2" of cementous fire coating on all conduits help this situation?
