stew
- federal way,washington
I have a panel replacement to do next week. In WA we are allowed to have 15 ft of serfice conductor inside the building without protection Heres the scenario, From the meter base there is exixting 2 inch rigid condout going down th wal into the sidewalk all concrete and then it goes under or possibly thru the foundation and is buried within the crawl space. There is a nearly full basement ,actually an old bomb shelter constructed in the 50's, There is a retaining wall in the back of this basement about 4 ft high where the basement ends and the crawl space starts. The rigid conduit is buried in the crawl space and only about 2 ft of it emerges at a slight angle into the existing panel. Is in your guys opininion this wire within the building? If so I would then need a disconnect to meet current code.It will be difficult to install a disconnect due to the fact that there is rigid into the sidewalk slab. Not impossible of course but costly and difficult . Am I "inside the building "when in a burried conduit in the crawl.? About a 20 ft run I would estimate.
