Service
pedro1200
Ny
While installing a or upgrading to 200a service with 4 individual meters. You would be required to install a 200a rated conductor to each meter, from meter to disconnect and then spply 83% if applicable, correct?
For a 100a service to each apartment yes but not if you’re requiring 200a,correct?
perhaps you could explain the setup in a little more detail. Is this a 200A service conisting of a 4 gang meter socket fed with 200A and then 4 service disconnects on the load side of the meters? OR is each meter 200A? Where is the service disconnect(s)?
First scenario
