teco
- Mass north shore
Hello all,
I would like to ask if anyone would give a rough estimate on this job. I would like to see if I am about where I should be. I always work for the same companies for years so I may not up with the rest of the contracting world but I want to make sure I am not giving the trade away.
3000 amp service. Pole set 40' from pad. Two 4 inch pvc raceways from pole to pad Two 90 bends in both pipes no wiring. Pad to be 20' from building. Eight 4 inch pvc raceways from pad to building with two 90 bends in each raceway. Come up from the ground to proper sized w-p can at base of building. Out of the back of the can directly through wall into main switchgear. Receive and set into place new 3 section switchgear. Wire is 500 kcmil thwn. Water meter and main is aprox 400' away wide open area 20' high. Assume total material cost to me is 75,000.00. My total installed estimate is 122,000.00 What do ya think?
Thanks.
Thanks.
