Services - Where the POCO job ends and the Electrician job begins
Sea Nile
Georgia
It would be very dangerous I think, being up on the roof so close to the neutral and an exposed phase conductor.
Thanks! It was installed in 1979. So I should call the POCO to have it fixed, not a local electrician then?
That particular termination your picture shows is an H tap.
Commonly called squeezon.
Around here it’s the POCO responsibility to tape it or put on that aggravating plastic cover.
Infinity has the answer. Call the poco to tape it up or tape it up yourself and forget it.
The poco won’t use a scotch pad though.
we tape them at the weatherhead but don’t at the transformer
I'll call the POCO. I'm not working that close to a phase conductor next to a neutral on the service side of my main disconnect.
Thanks All
you want the weather head ripped off the house or the wire to go down first?
I agree, I just don't want to lose my neutral if a branch from the tree falls that would never have enough force to take down the weatherhead.
I've never seen a lost neutral happen in that dramatic of a fashion.
I have many times, although it’s a crap shoot as to whether the phase wires or neutral wire break apart first and where it comes apart.
Check this one out. It was right near a set of metal steps to access the roof. I told the owner how un-safe it is. He just laughed.
'It's still like that.
