Good morning
If you have two independent services coming into the same building / same switch gear room can you cross your secondary wires. Example: I have two 3000 amp services each one consist of independent pull sections going to its own switch boards feeding there own meter centers, above both 3000 amp services I'm installing a UL rated/listed crown box, so my conduits in gear room doesn't cross, now can my conductors cross over from 3000 amp to 3000 amp switch boards within crown box.
