bgbbgb246
- Redding Ca,
- Electrical Engineer
I have an application which requires a motor to rotate a cylinder. The cylinder will be up to 24 in. in diameter weighing up to 250 lbs. Density will be equal throughout. Generally for this type of application, I would see an induction motor but a wide speed range that includes very low rpms (0.31rpm) is pushing me to, at least look into, a servo. Upon attempting to cross reference a 3 phase induction motor to a servo, I noticed a pretty large discrepancy in rotor inertia between a servo and induction motor of comparable size. For example, using 2 Automation direct products comparable in terms of kW rating.
1. Marathon Black Max, Y547, is a 10HP or approximately 7.5 kW motor. Its full load torque is 29.5 lb ft. Its rotor inertia is 1.3 lb ft^2
2. SureServo2 High Inertia Servo Motor, SV2H-475N, is a 7.5kW motor. Rated torque 35.21 lb ft. Its rotor inertia is 142.7 x 10^-4 kg m^2 or 0.3389 lb ft^2 if my conversion is correct.
My concern is the huge discrepancy in rotor inertia that would seemingly suggest that I would need a servo possibly 4 times the size as the one with a comparable kW rating if sizing by inertia ratios. Can anyone provide some insight on what I’m running into here? I don’t spec out motors very often so I’m assuming that my inexperience is misleading me.
Servo Data sheet https://cdn.automationdirect.com/static/specs/ss2motors.pdf
Induction motor data sheet https://cdn.automationdirect.com/static/specs/motorsblackmax.pdf
