therobthompson
- California
- Builder
Hi. I installed some 120V LED pathway lights in the exterior wall of a new bathroom. Also on the exterior is a photocell to turn them on/off at dusk/dawn, and an on/off switch to disable them. Turns out the lights are too bright. In hindsight I should have ran hot to the photocell first, then the switch, so that the switch could be a dimmer (the path lights are dimmable). If I install a dimmer now, it will feed the 'dimmed' power to the photocell, which I'm guessing won't work. Opening the walls at this point is an ugly proposition. Is there a tiny dimmer module of some kind that would fit in the 1 gang box behind the photocell? I don't need to access it and control the brightness, just adjust once and leave it in the box. Or is there another way? Thanks!!
Rob
Oakland, CA
Rob
Oakland, CA
