Sewage and water lines above electrical duct bank
anbm
TX
Designer
Will it be code violation if sewage and water lines run above or below the underground electrical duct bank (with 480V wires), the electrical ductbank is the service feeder to the building. Is there a minimum separation distance requirement between elec. ductbank and sewage and water line conduits?
Typically water is above sewer or has horizontal separation, dictated by those utility requirements. NEC does not address but if service conductors POCO may have requirements. Duct bank would not require maintenance but water and sewer can have taps made at later date.
