Can anyone tell me if stainless floats utilizing integral rubber cords are acceptable to be used in municipal sewage pumping wells. The voltage being applied is 120v. Some are terminated at terminal strips outside the well on intrinsically safe barriers others do not use the barrier. There is no listing on the float that would indicate that they are acceptable to be used in this environment. NFPA 820 lists this area as class 1 division 2.and approves extra hard usage cord, which these are, for this type of classification when flexibility is needed for the removal of equipment. Thank you
[ December 29, 2003, 01:49 PM: Message edited by: patc ]
