I am installing a 120v circuit to an outside sewer grind pump.The float and the
pump have a factory installed 4' cord with a 15a male cord cap.The pump cord plugs into the back of the float male end and the float is made to plug into a receptacle. This is a residential installation and the pump is about 15' from the outside of the garage wall.My question is can i cut the cord ends off of the cords and wire this direct with a disconnect located on the outside of the garage wall and do away with the gfi ?or do i have to install a gfi receptacle and inuse cover?
The pump is below ground level.
Please advise of code article that applies.
Thanks.
Thanks.
