Is explosion proof seal off fittings required between the control panel and the pump chamber per NEC? I work at several manufactured home communities. One community pumps to city sewer lines has huge 3 phase pumps and has explosion proof seal off fittings between pump panel and pump chamber. The other communities pump up to leach fields and have private septic systems. These systems do not have explosion proof fittings installed.These are smaller single phase systems. Are they required for just the city sewer system or for that matter at all. This make replacing floats and pump feeds impossible without splicing them. Please advise. Thanks
