JerryHonolulu
I have two panel feeders, each including an equipment grounding conductor, that go from the service panel to two panels located in a pool pump room below grade in a separate building, located directly adjacent to each other. The electrical conctractor installed a 10' X 5/8" driven ground rod horizontally through the foundation wall at 6' below grade into undisturbed soil.
A grounding electrode conductor is routed to the first panel ground bus, then extended to the second panel, both panels thus sharing the single grounding electrode.
Is this the proper grounding for these two panels?
Thank You.
Thank You.
