Re: Shared Holes
How much difference is there between a lighnting protection system down conductor and a grounding electrode conductor?
Separation from lightning protection conductors is mandated by the NFPA 780. Doesn't the GEC and the lightning protection conductors practically serve the same purpose?
In many cases, not only does the GEC run through a hole with another cable or cables, it is run through the attic of the structure along with many of the branch circuit and feeder cables.
I doubt there is any documented cases of problems with the installations described above, however that doesn't always mean its okay.
I think grounding electrode systems are a big waste of time to start with, but if we are going to start directing surges into the structure due to electrode location, precautions should probably be made?
