Does anyone know of any provision in the nec, or any other good reason NOT to wire in the following way: 2 gang switchbox, fed by a 15 amp circuit. Take a 14/3 from the switchbox to the first light, powering it with the black wire from it's switch, proceed from the first light with 14/2 to second light, having grabbed the red wire from the 14/3 which is from the other switch. So we have 2 lighting loads sharing a common neutral down the 14/3 to the 2 gang switchbox. It's a single phase service. ANY reason not to do this?
Thanks!
Thanks!
