washingtonw
New member
In a commercial application, can the neutral be shared between two or more receptacles fed from the same phase? If so, does the neutral have to be sized to accommodate the return for both circuits at the same time? For instance, if the(2) circuits are rated for 20 amps does the neutral have to sized for 40 amps?
Thank you.
Thank you.
