Shared power
sparky23
texas
I have a single j-box with a power leg - from here I Have 2 light fixtures and 2 switch legs. I have attached a diagram.
what is wrong with this diagram?
I was not able to run light after switch -
thank you in advance
charlie b
Lockport, IL
Semi-Retired Electrical Engineer
What's wrong with the diagram? Nothing. :happyno: Why doesn't it work? Several possibilities come to mind:
  • It is not, in fact, wired that way.
  • One of the switches is broken.
  • One of the lights is broken.
  • A connection is loose.
sparky23
texas
blew a switch - existing metal box - wire good no scars - but neutral sparked.
Suspect water in switch leg - this is an outside switch but covered by carport.
thanks
just puzzled and do not want to repull switch leg... zero access and no money in job to spend on repairs.
