Shared Trenching
Joe.B
Myrtletown Ca
Building Inspector
Does anybody know of any NEC sections addressing shared trenches? Specifically any required separation between gas and electric? Thanks!
It’s just good sense even though it may not be applicable in all instances..
That would be ridiculous. If separation is needed or required, a distance should be given. I don't see what a trench has to do with it.
Thanks for the input. I think separation is wise, but without a code reference I can't/won't enforce it. I recommended pushing the gas tight to one side, and electric to the other in his 12" wide trench. I recommended a trick I saw that helps, using scrap pvc conduit to make stakes, it makes for a clean, stable separation.
On the POCO side it's easy because their requirements are more strict than building code. Private side is far more lenient, I guess you can't sue the POCO if it's on your side.
