sparkslord
I thought that you could share a conduit as long as all the conductors were fused. Someone suggested this may be a violation.
What I have is a pole away from the house with a panel, well controller, and variable speed pump controller mounted on the pole. The feeders from the house go through an in-ground vault. The feeders OPD is at the house. Can I share the conduit going to the vault from the panel on the pole. The LV control wiring for the Variable speed pump has a separate conduit system.
This is not a question about deration or conduit fill. I just wanted to confirm that this is not a violation.
