- Lockport, IL
- Retired Electrical Engineer
Designing an aircraft engine test facility. Test stands and equipment provided by user. I need to provide a cable tray from one side of building to test stand. Cables are for control and communication between control room and test stands. But they also need to bring the fuel line to the test stand along the same path. Previous similar facilities have run the low voltage cables and the fuel line in the same cable tray. Are they really allowed to share?
The fuel line is about 1/2 inch in diameter, is flexible enough to route in cable tray, and is very robust (not likely to break or leak). The fuel is JP8, a non-volatile liquid (i.e., no flammable vapors; you could put you cigarette out in a pool of it).
