A customer called the shop with a voltage problem that is burning up boards at a MRI facility.The service is feed from a 1200 amp gear that is located outside.From the gear a 400 amp breaker feeds the facility with 500 mcm to a self contained 400 amp 3phase mtr can.From the mtr can the customer did not run a ground to the 2 200amp panels instead he is using parr. 2 in. emt conduit.Inside he is also using just the conduit for a ground on all his branch circ. and he is sharing neutrals.Should this have deicated neutrals and grounds to this euipment?The load on the service is about 30 amps so its not overloaded
