360Youth said:I've posted these before, but they are just about my favorite tool every time I use one, which is just about daily. I haven't used a self-tap/terk screw in a long time.
http://cgi.ebay.com/Greenlee-6-32-1...0-DTAPKIT_W0QQitemZ130147627982QQcmdZViewItem
infinity said:What does the plastic bar mount have to do with threaded machine screws? Did he cite a particular violation? IMO he's incorrect unless there is a listing issue with using the screws that came with the bar. To me that's a stretch.
Were they tapped holes that you used already in the panel?
monkey said:It was a former main panel converted to a sub panel. I installed a grounding buss with 10/32s, and I removed the neutral bus, placed plastic mounts under it, and fastened it to one threaded hole with a 10/32, the other with a TEK screw since there was no second hole. I couldn't tap the second hole because the enclosure is mounted on a brick wall with a ramset. The only way I can tap it is to destroy my drill/tap when it plows into the concrete.
360, I use those all the time. Looks like I'll be buying a new 10/32 tho.
http://cgi.ebay.com/Greenlee-6-32-1-4-20-6-Pc-Drill-Tap-Set-17620-DTAPKIT_W0QQitemZ130147627982QQcmdZViewItem
acrwc10 said:I was looking at those and wondering if they were any good, Now I am going to buy them. They look like they are faster them a box tap.
mattsilkwood said:ive got a set and love em, but i make a pilot hole the put the tap in my
10 in 1 works out slick. ive broke a few in the cordless ecspecialy the small ones.
monkey said:I couldn't tap the second hole because the enclosure is mounted on a brick wall with a ramset. The only way I can tap it is to destroy my drill/tap when it plows into the concrete.
480sparky said:
