mstrlucky74
- NJ
Guess in an commerical office space with hung ceilings when does the sheetrock stop at the hung ceiling and when does it go all the way up to the slab/or deck? Asking because I guess the only time you would need to firestop your work( if fire rated wall) is if the sheetrock went up past the hung ceiling. Otherwise your conduits/cables would just be supported above the ceilings going from room to room and not penetrate any walls. See attached.
