Sheetrockers
Fordean
New Jersey
Electrical Contractor
Have a 4 foot run Turn Sheetrockers leaves loose stud to slide a sheet in Instead of liners
He states go overhead use splice box on top of plate and drop done two whips Which 1 make uneeded splice 2 alot of extra work Literally need to go 6 feet around corner They state we just cut your wire How u respond to this
Kill the power to the room . Take the wiring right out of the main breaker, because they are going to try flipping breakers back on. Most sheet rockers are still using electrical powered drills to sink the drywall screws. Then tell them, be nice boys and I'll give you back some power to run your stuff. But you gotta go the long way.
Metal studs? Just run the cable in the bottom track where the two walls meet.
Wow, times have changed! The sheetrockers I've worked with notched the rock where my pipe or cable was. Slid the sheet right in.
Ron
