Re: Shelf Life Information for DC Battery
I work for a municipality, we install, use and maintain a variety of batteries. We have battery analyzers that take battery, discharge and charge it three times, and then display the amphours. We have found some 25 % capacity batteries can be recovered to over 100% of rated capacity. this tester has interchangeable modules for different batteries, will analyze ni-cad, gel cel and NiHydride, etc. I have found the best ni-cad battery chager is one that pulses the battery with a higher voltage DC pulse. I have a small solar panel on my personal pickup, it puts out a 18 vdc pulse and maintains the battery, it does not let sulfates build up at the bottom of the battery.
For home camera use I have been using the RayoVac Ic3 battery system, it charges the battery in 15 minutes, and they have a fairly high capacity of 2,000 mA hours, which we have tested at 1800.
