mshields
- Boston, MA
I have a somewhat unusual requirement where by I am running a 30A 480V feeder to Box in a radiology room. The cabling to that box will be “run of the mill”, THHN/THWN in conduit. But from the box to the equipment, a run of cable that is no more than 10 feet, I need shielded conductors and I need them to be rated to be run exposed.
If they weren’t shielded e.g. I would specify SO cable as we sometimes do with branch circuit connectors to receptacles dangling from a ceiling.
The circuit is, as I mentioned 30A but we will need to use #6’s AND there will be no neutral and the ground needs to be equal in size (#6AWG)
I’m envisioning 4 separate cables but a cable assembly might be workable. Any suggestions.
