posttoasties
New member
It is my understanding that under NEC requirements you must use shielded cable when running above 2400V. Someone also told me that if you have a transformer that has a voltage tap above 2400V you must use shielded cable whether or not you are using the tap or not. For example if I have a transformer that has a 2000V tap and 5000V tap, they claim that I need to run shielded cable coming out of the transformer no matter which tap I am using because the transformer has at least one tap that is rated greater than 2400V. I have not been able to find any code to support this claim and was hoping someone had some information, thanks.
