We have a 6,300 kW wound rotor induction motor.
The stator voltage is 11 kV, 50 Hz, the rotor 3.2 kV
It is run up to about 1000 rpm using a stepped resistance starter.
Then it changes over to variable speed control over the range 1000 rpm to about 1485 rpm.
It drives a compressor.
The speed controller comprises a rotor rectifier, a step up chopper to about 950 Vdc, then through a mains commutated inverter into a 950 Vac recovery transformer which steps it up to the 11 kV supply voltage. Sounds complicated but it is done in the interests of efficiency - around 96% efficiency including the drive and motor. And we had to prove it.
But my question is very simple. If there was a short on the 11 kV bars, how much fault current would this arrangement add?
