It can be valid either way, depending on the UL listings and tested combinations.that can be valid if the main is disconnect switch not circuit breaker?
Series ratings between breakers and fuses, often requires the use of Class J instead of typical Class R.that can be valid if the main is disconnect switch not circuit breaker?
