Re: short circuit method?
This is the third thread you have started, and you have asked the same question in all three. After having re-read at all three, I still don?t understand what you are looking for.
Would the following three statements give you the answer you need?
(1) No. The NEC does not require the performance of a short circuit calculation.
(2) If you desired to perform a short circuit calculation, the NEC does not give any methods by which such a calculation could be performed.?
(3) Short circuit calculations are part of the design process, and are not addressed in the code.
