When calculating available short circuit current, do fuses allow you to reduce the available short circuit on the load side using a fully rated system?
For example, if the utility short circuit is 100,000 and if calculating short circuit to be 80,000 for a panelboard, if you install a fused disconnect right before the panelboard which gives 22,000 on the load side let through current let's say, then can the panelboard be rated for 22,000 for a fully rated system OR is this considered series rated short circuit current?
