- Tennessee NEC:2017
- Semi-Retired Electrician
I've heard of a heating element shorting to the tank, and that usually just results in a high Utility bill. But if it is shorted enough, and the EGC is intact, shouldn't it trip the breaker? I'm speaking of an element that has sediment build-up that bridges the gap from it to the tank.
Is it possible, even with the EGC connected, and the thermostat not calling for heat, for the element to heat the water to an excessive temperature and not trip the breaker? I do know that the elements have 240V, with one leg remaining on, and the other controlled by the Stat.
