Hi, quick question. First of all here is the scenario:
I have an external 24vdc power supply for a DI module on a certain PLC. The common side of the supply is grounded. There is a common fuse in the module to which the 24vdc is connected to. I have two pushbuttons connected to the inputs of the module with slow blow fuses between the module and each pushbutton. If i short circuit the external power supply, what should happen to the fuses between the pushbuttons and the DI module? How about the main fuse?
