Re: Shorts in wiring
?TDR? stands for ?Time Domain Reflectometry.? It?s all about measuring the time needed for a reflected wave to make it back to the source. I studied it in college, so it is not a new technology (I graduated during the reign of Augustus Caesar). Its basic principle is similar to that of radar and sonar. The machine sends a pulsed signal down the conductor. At the end of the conductor, the wave is reflected along the wire back to the machine that created the pulse. Measure the time required for the wave to make the round trip, multiply by the speed of the wave, and you get the distance traveled by the wave. Divide by two, and you get the length of the conductor. You knew that length anyway, so the answer will be no surprise.
But if there are any ?imperfections? along the path, a part of the wave will be reflected back from the point of the imperfection. You can get the distance from the source to the point of imperfection in the same way described above. In this sense, an ?imperfection? is any point at which the resistance of the conductor changes. If you tap into the conductor and run a second circuit, the TDR will show the distance to the tap point. It will pick up a twisted and wire-capped connection in a junction box. And it will pick up the point at which a nail was driven into a conductor.
Keep in mind that all a TDR can tell you is the distance along the conductor to the point of imperfection. You will need to know how the conductor is routed through the floors, walls, and ceilings, in order to find the exact location of the point in question.
Do a google search for Time Domain Reflectometry, and you should find plenty of information.
Here is a tutorial that I found:
TDR Info
