A common issue I see in the land of pipe, in homes particularly, is corroded panels. Enough water can get through the meter enclosure into the pipe (or alone the outside), surface tension down the wires probably, and drip into the panel to cause issues over time, failed MBs especially as it tends to go right in those. This is for full basements (or similar), where you poke the pipe through the meter/siding horizontally, then 90 directly down into the top of the panel. I feel like having a pronounced goose neck would keep almost all of that water out of the panel. Yes, there's duct seal or caulk (often ignored by installers), but I feel like a simple goose neck would be more reliable over time. Physics > goo.
Should this become a common requirement for conduit installs?
