Should I bond ground and neutral in this unusual case?
jar349
New User
Pennsylvania
Software
I am installing an offgrid solar system that is not attached to the utility grid - except that the offgrid system's ground electrode conductor is connected to my house's ground electrode conductor via a bonding jumper.
Obviously, my house's main service panel has ground and neutral bonded there and nowhere else. However, as I am wiring up my offgrid equipment, I bonded ground and neutral in the offgrid system's main service panel (that is, the panel that is backfed by a circuit breaker fed by a standalone inverter and has the breakers for the AC loads).
Realizing that my offgrid system is now sharing a ground electrode conductor with my house's and that my house's ground electrode conductor is bonded to neutral in the house's main service panel... I am confused as to whether the offgrid system's main panel should also have its ground and neutral bonded.
But if you tell me that I should NOT bond my offgrid system's ground and neutral, then how will my offgrid system's circuit breakers open/trip in the event of a ground fault in my offgrid equipment?
And if you tell me that I SHOULD bond my offgrid system's ground and neutral, is it possible that a ground fault in my offgrid system could harm circuits and equipment connected to my house's utility-connected system (or vice-versa)?
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
