I'm troubleshooting some problems in old wiring (about 10 years old) at an estate. There are a number of outdoor lighting circuits. Some of the switches are in open air and these are behind wet location switch plate covers. Some of the switches are in semi-enclosed areas (like a porch or covered walkway) with standard indoor "decor" switches. But NONE of the circuits are GFCI protected, at least not from the source.
One interesting circuit goes from the circuit breaker to the pool area where there are some 3-way switches, one set by each entry to the pool deck. These are behind wet-location switch plates, but no GFCI between the breaker panel and the switches. These switches provide power to low-voltage transformers for pool deck and landscape lighting, and there are GFCI receptacles placed in the circuit just before the low-voltage transformers. So the GFCIs will protect against a fault in the transformers only; not anything upstream (like at the switches). I don't think this is correct. I don't think the indoor switches belong in the semi-enclosed locations either, as it wouldn't take much wind for them to get doused in a a rain storm.
