Ben Trueblood
checking the interpretation with a couple of questions:
If a show window is less than 6 ft. in width is a receptacle required?
If the window is wider than 12 ft. (2) receptacles are required and so on?
Do I have to use the 200va per linear foot to calculate load or can I use 180va per outlet methos which would not require a dedicated circuit?
