J johneymac Member May 19, 2010 #1 I'm installing a 120v recessed light fixture with a rated shower trim and gasket in a shower stall. Does this fixture need to be gfi protected,if it does can you give the code section,thanks johneymac.
Jim W in Tampa Senior Member Location Tampa Florida May 19, 2010 #2 No not unless the install directions call for it.
Steve Beranek Member Location St. Louis, Missouri May 19, 2010 #3 No GFCI needed, just install it right
